voicemail keeps failing
  • Jun 6, 2022 3:24 PM UTC
  • 2 replies
  • 113 views
Hello my voicemail keeps failing and going to error.
  • Jun 6, 2022 3:33 PM UTC
Hello
When did it happen? Can you dial your own number from your Koodo handset and see if you can reach your voicemail?
To try to reset the voicemail settings, can you reset the network settings of the phone?
  • Jun 6, 2022 4:41 PM UTC
Hello,
Thanks for responding. I fixed the problem by turning the phone off and back on.
