Locked iPhone
  • Jul 11, 2022 6:40 PM UTC
  • 1 reply
  • 245 views
If I am already a Koodo customer. I bought a phone that is also with Koodo but it is locked.
Am I able to switch my SIM card to the new phone since both are with Koodo? Or does it still have to be unlocked to do so?
Thanks!
1 reply
  • Jul 11, 2022 7:24 PM UTC
If the phone was locked to Koodo, you can simply put the SIM card in it and use normally.
If you want to unlock, you can follow this https://www.koodomobile.com/en/help/unlocking-your-phone
