stop roaming on U.S.
  • Mar 27, 2022 5:37 PM UTC
  • 1 reply
  • 183 views
I live about 10 km from the US border and my phone often sends me notice im on US towers and using easyroam . I dont want this . I have turned off roaming and my network is set to koodo but its still doing it . Is there something else i can try ? Thanks
Best answer by Timo Tuokkola
Manually search for available networks, then select Koodo. This should keep the phone connected to Koodo's network until the next time it is restarted, at which point it will revert back to automatically connecting to the strongest available signal.
1 reply
Timo Tuokkola
  • Mar 27, 2022 6:41 PM UTC
