voicemail keeps asking for password after being out of canada
  • Mar 25, 2023 11:27 PM UTC
  • 9 replies
  • 592 views
I travelled out of country, used Easy Roam, and now back at home the voicemail insist I must  enter a password. I’ve done that, I’ve even reset it, I’ve done #4#4 to make it on and turn off again (asking for password) but it is still asking.
Clues?
tx
Best answer by Boa_Guy Koodo
Hi there @Moogie   We have looked into your account, everything looks to be set up correctly. We have refreshed the backened just to be on the safe side. Please try again, and if you are still having the same issue, you will need to schedule a callback with a tech so they can look into this and possibly solve your issue.  You can schedule a callback here: http://koodo.com/chat.
  • Mar 25, 2023 11:51 PM UTC
I’m not familiar with the #4#4 code. Below are the step-by-step instructions on resetting your voicemail password. If you are still having difficulty, let us know.
Step-by-step instructions
  1. From your handset: Dial 1 + your 10-digit phone number + Send or Long press 1.
  2. When prompted, enter any password.
  3. After 1 failed attempt, you will be prompted with "This is not the correct password. Please try again, or to reset your password press the STAR (*)
  4. Press 1 to have a temporary password sent by SMS to your phone.
  5. A temporary password will be sent to your phone. Please access your mailbox again using this password.
  6. The SMS will show as follows "Your temporary password is XXXX"
  7. To reset your password, please hang up and call into your voicemail again from your mobile phone, enter the temporary password that was sent via SMS and then follow prompts to enter your new password.
  • Guardian
  • Mar 26, 2023 12:04 AM UTC
Sorry: option 4 then option 8, (option to have phone ask/stop asking for password). I’ve done all of the above (made a new password, set to “don’t ask for password) but it still asks for the password. If I go to option 4 then press 8, it’s already set to not asking, my only option is to set to ask. I’ve done that back and forth, it asks no matter the setting.
thanks for your help, what’s next?
  • Guardian
  • Mar 26, 2023 12:54 AM UTC
I’ve also rebooted the phone in between
  • Mar 26, 2023 1:08 AM UTC
You do not have to reboot your phone when resetting your vm password, though this indicates that a reboot is not clearing the issue. Would you like me to flag a rep to look into this?
  • Guardian
  • Mar 26, 2023 1:15 AM UTC
Yes, thanks.
Just outlining all the steps tried in case leaving and returning to canada messed something up.
  • Mar 26, 2023 1:33 AM UTC
Yes, thanks.
I have flagged a rep to look into this for you. I’m not sure why bypassing the password prompt is not working as it should. Perhaps they can shed some light on this.
  • Guardian
  • Mar 26, 2023 2:12 AM UTC
Excellent, thanks.
Boa_Guy Koodo
  • Koodo Alumni
  • Mar 27, 2023 5:01 PM UTC
  • Guardian
  • Mar 27, 2023 5:30 PM UTC
Thank you, that seems to have worked, no password now. Cheers
