voicemail
  • Sep 19, 2023 7:47 PM UTC
  • 3 replies
  • 208 views
My voicemail says it needs a number. However, I put in the number given associated with my area code and it says I cannot change my number...... what in the heck ?
  • Sep 19, 2023 8:06 PM UTC
The voicemail number is your own phone number.
I've tried that as well
 Does not work
  • Sep 20, 2023 12:21 AM UTC
Voicemail normally needs their voicemail center server. Your phone number wouldn't work. The number normally was automatically set by Koodo though. Can you try to reset network settings of the phone to see if that can help.
As well, you can call your self from your Koodo handset. That technically will call your voicemail.
