MMS won't send long texts but send pics
  • Sep 9, 2023 4:57 AM UTC
  • 3 replies
  • 118 views
Hi folx,
I have a new phone and although I can send pictures through text, I cannot send longer texts.
Things I've done so far:
* Checked that MMS is switched on
* Checked that my data is enabled
* Checked that my data is working
* Tried numerous times to hit resend
* Turned power off
* Cleared cache of my messaging app
* Cleared memory of my messaging app
* Cleared cache of all of my apps
* Factory reset
I've read just about two dozen articles in trying to fix this issue to no avail. Any new ideas would be appreciated.
  • Sep 9, 2023 5:47 AM UTC
Which phone are you using?. If you are using an Android, which app are you using for messaging? Have you google Message?
  • Sep 9, 2023 4:16 PM UTC
I am using a Samsung s10 and I'm using the Samsung messaging app
  • Sep 9, 2023 4:30 PM UTC
Could you  download the Google Message app in from Google playstore and  test if the the issue follow?
