Easy roam toggling
Hi
What is the best way to toggle on and off easy roam while overseas?
During my trip I will have wifi for few days and would like to know how you guys manage to easily toggle on and off easy roam to avoid being charged on the days wifi will be available. I would like a solution other than putting my phone in airplane mode.
Thanks
Best answer by Dennis
There is no need to toggle Easy Roam on and off unless you want to use Pay Per Use Roaming.
The Easy Roam charge only applies when you use data, talk, or sending a text.
During the days (starts midnight) when you dont use cellular data, voice, or send a text, no Easy Roam is charged.
Note your Easy Roam day ends at 11:59pm
Did this help you find an answer to your question?
  • 29055 replies
  • March 12, 2025
  • 6176 replies
  • March 12, 2025
To ensure that you avoid any unnecessary roaming charges, you can remove your SIM card and insert it back when you need to use your phone.
  • 13561 replies
  • March 12, 2025
Even in airplane mode, you can turn on wifi and bluetooth, while cellular remains off.
