Data not working without VPN
  • Nov 25, 2026 2:21 AM UTC
  • 2 replies
  • 20 views
So my data seems to not be working out of literally nowhere. No apps, no nothing, and I even tried using someone’s hotspot and it still didn’t work. I reset my phone (iPhone 16), updated it, reset network settings, all the usual suspects. I have full data since my billing month just restarted. However, because of an article here I tried turning on my VPN, which I had to “untrust network”, and so far it seems to have worked. Is there a way to not need the VPN turned on in my own house? Not the end of the world now that it’s back, but it’s more so the fact that it was working just fine before, I don’t know what changed to have that happen. Also, no one else using the Koodo internet has the same issue, it’s just me, which makes me wonder if it’s my device.
Anyways, thanks in advance!
Best answer by Dinh
Since it also didn't work on someone else's hotspot, I doubt it's the Koodo line or network. That points to something on the iPhone itself, especially since nobody else at home has the issue.
I wonder if the VPN app is actually part of the problem. Someone here had their hotspot connect fine but nothing would load until they disabled part of their VPN config https://community.koodomobile.com/plans-add-ons-66722/do-koodo-plans-support-personal-hotspot-7819668
Can you check Settings > General > VPN & Device Management for any profile installed there, like a VPN, ad blocker or DNS filter? I would try removing it (you can reinstall it later), restart the phone and test again with the VPN off.
As well, when it fails is it on your home wifi, cellular data, or both?
  • Nov 25, 2026 2:32 AM UTC
  • Nov 25, 2026 3:03 AM UTC
Omg it worked!! Thank you so much!:)
