OnePlus Nord N200 mobile data not working
  • January 27, 2022
  • 2 replies
  • 413 views
I bought a OnePlus Nord N200 phone. I can make phone calls with it using my KOODO sim card, but I can’t use mobile data. My mobile data is turned ON in the phone’s settings. Any advice?
Best answer by MrBucket
Okay, I managed to fix it by deleting the existing APN in my phone’s network settings and following these steps: https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone?search_api_views_article_search_fulltext=APN
Did this help you find an answer to your question?
  • Rockstar
  • 1 reply
  • January 27, 2022
  • 17383 replies
  • January 27, 2022
For some reasons, some oneplus devices had trouble to get APN settings automatically. Customers had to manually fix it. It is great that you find the solution. Cheers!
