NO SIM/Emergency Calls only
I got a new dual SIM phone and put my SIM card but unable to make/received a call as it says Emergency Calla or NO SIM card. Need help please!1
Did this help you find an answer to your question?
  • 5960 replies
  • March 9, 2025
Hi ​@Phoebe1
If you put the sim in a different phone, is it connecting to the network?
Is your new dual sim phone supported on the Koodo network?
You can check here if it is supported https://www.koodomobile.com/en/help/phone-compatibility
  • 1 reply
  • March 9, 2025
It is supported but still on Emergency Calls.
  • 13565 replies
  • March 9, 2025
Does it show that it is connected to any network? Do you have automatic network selection mode on? What’s the phone model?
  • 29057 replies
  • March 10, 2025
What phone is it?
Does the phone use dual physical sims or is it 1 physical sim and the other is an esim?
