easy roam US
  • Jan 12, 2023 1:13 PM UTC
  • 3 replies
  • 218 views
I’m having trouble ading easy roam US to some of my lines.  I get the option to add easy roam INTL but if forces pay per use for the US and I can’t find a way around this.  Any thoughts on resolving this?  Strangely, one of my 4 lines has both the US and INTL easy roam options activated.
Best answer by Boa_Guy Koodo
@Scootero   After checking, we can confirm that you have the correct add-on. It is now called “Easy Roam US - PayPerUse Access On”  It was renamed to make it more clear for our customers so they know that they are only being charged for it when they use it.
Sophia
  • Jan 12, 2023 1:55 PM UTC
Can you explain exactly what error or message you are getting?
Boa_Guy Koodo
Hi there @Scootero  It's normal, when you add Easy Roam, the system will also add the Pay Per Use INTL add-on as it's required for it to work.
Edit: Ok, we see what you mean. Let us take a look and we will get back to you with our findings and or solution.
Boa_Guy Koodo
  • Koodo Alumni
  • Jan 12, 2023 3:01 PM UTC
