CAN'T LOGIN TO PREPAID SELF SERVE
Am I the only one experiencing this?
I’ve tried clearing cookies and cache, multiple times, I might add.
Tried it on Chrome and Edge, tried using my laptop, and two different phones, tried using incognito mode, even tried to reset my password but only getting, “We are unable to process your request at the moment.”
It’s really frustrating!
Did this help you find an answer to your question?
4% of voters found this helpful
StevenRanger
I can’t sign in either.  Said my credentials were wrong.  Set up a new account and still can’t sign in !!!!!
  • Member
  • 1 reply
  • March 5, 2025
Same issue and cannot get any actual assistance from this useless AI garbage assistant.
  • 6007 replies
  • March 5, 2025
Hi ​@Chimdi ​@StevenRanger ​@TKO
Thanks for sharing!
Can you please check again and let us know if you are still encountering issues with the self serve login?
  • 2 replies
  • March 5, 2025
Thanks but it's still not working
  • 6007 replies
  • March 5, 2025
Thanks for checking!
Just to double check, have you tried in a different browser or in incognito mode?
  • 2 replies
  • March 5, 2025
Okay, so I've been able to login but can't add a card to pay my bill. I keep getting an error message. I've tried both credit and debit cards
Mary Beth MacIsaac
I’m having the same issue.  I changed my password as required but can no longer login, I get the “logout or clear your cache” message.  I’ve tried on different browsers and on my phone, same message.
  • 6176 replies
  • March 6, 2025
You may want to schedule a callback through Koodo Assist and speak with a rep to assist you with the Self-Serve account. https://widget.telus.tiia.ai/koodoprepaid/koodoprepaid.html
  • Advisor
  • 13 replies
  • March 6, 2025
Still does not work.
If I type the new password, I get “Logout or clear cookies first”.
If I try some incorrect password, I get “Either email or password invalid”.
So, the new password is clearly recognized, but it does not let me in.
I tried clearing cookies, did not help. Tried the incognito mode, same error.
Hi ​@discovery, you can also try to log in using a different browser or device. If you still have no access, we’d recommend you schedule a call-back through the Koodo Assist so our prepaid team can reset your online account.
  • Advisor
  • 13 replies
  • March 6, 2025
Same issue on Android and in Edge on Windows. Will schedule a call-back tomorrow.
Gail Hibbs
Koodo, having the same issue.  You should really test your updates before putting in place.  This is very frustrating.
  • Advisor
  • 13 replies
  • March 6, 2025
If I try to schedule a callback, the chatbot simply says it does not undersantd me. What a fiasco.
  • Advisor
  • 13 replies
  • March 6, 2025
It wants me to login in in the chat to schedule a callback. But I cannot login. Would somebody be able to assist?
  • Advisor
  • 13 replies
  • March 6, 2025
Ok, scheduled a callback on my monthly account to talk about the prepaid login issues. Even that took a while to convience the chatbot I need a callback.
Mary Beth MacIsaac
Unfortunately I’m not able to schedule a callback. The link you provided takes me to the chatbot and when I try to schedule a callback this is the response I get:
2025-03-06, 11:03:54 a.m.
Me: Schedule a callback
Chatbot: Sorry, but I don't quite follow. Could you rephrase with short keywords, please?
  • 13588 replies
  • March 6, 2025
I’m having no issues getting the assist to let me schedule a callback for numerous issues. I just cannot directly ask the prepaid assist for a callback. You can say account locked on the prepaid assist to get the option.
  • 6176 replies
  • March 6, 2025
Try “schedule call” to see if it works.
  • Advisor
  • 13 replies
  • March 6, 2025
I am on hold right now with Koodo. Waiting for the prepaid secialist.
This clearly needs to be escalated to backline engineers. It is not a one-off issue.
Guessing what magic words to tell the chatbot is not an answer. “Schedule a callback” works just fine on the monthly account after authentication. But customers need assistance with a prepaid account where they cannot log into, and “schedule a callback” there simply does not work.
  • 4 replies
  • March 6, 2025
After I changed my password based on recent instructions I can’t login to my account anymore.
Password reset doesn’t work either.
Please help.
  • 13588 replies
  • March 6, 2025
Well, it’s not what the answer should be, but it is the answer when it’s partially restricted in how to get  a callback scheduled. It’s certainly something that should also be enabled the same way it is on postpaid, but prepaid tends to be the red headed step child of Canadian telecomms.
  • 13588 replies
  • March 6, 2025
Please help.
I’ve flagged a rep to assist.
Mary Beth MacIsaac
I’m using the chatbot options to try and schedule a callback and they’re not working.
  • 6176 replies
  • March 6, 2025
Let me flag a rep to help you out.
  • Advisor
  • 13 replies
  • March 6, 2025
The rep on the phone somewhat vaguely confirmed about the known issue with the new login system. He is opening a new internal support ticket now. They will look into this, and will call me back tomorrow. I did mention this thread as well.
