how to get easy roam in cuba
  • November 1, 2021
  • 2437 views
Pie Petrie
I had no internet access. So I bought a cuba SIM card here in Cuba. Then went and added easy roam. Then I added my Canadian SIM card back in my iPhone. I still have no internet to text or calling. And I need to do banking and it won’t allow me because it sends security code to Canadá phone number
Best answer by MilkyWay
Pie Petrie wrote:
I cannot get anything with my Canadian sim. I added easy roam with my access with my Cuban sim. But then I transfer to Canadian sim and nothing.
According to the list of partner companies, only one Cuban network is compatible. Were you able to see Cubacel on the list when you were searching for a network manually?
Did this help you find an answer to your question?
Pie Petrie
  • 1 reply
  • November 1, 2021
  • 12008 replies
  • November 1, 2021
DO you have 2 phone SIM in your phone? If you do, make sure the Canadian one is selected for data.
  • 29080 replies
  • November 2, 2021
With your Canada sim in your phone, check your mobile network selection from automatic to a local Cuban network
  • 6176 replies
  • November 5, 2021
I I am off to Cuba from Ontario 6 a.m. Sunday morning I have added easy room to my account any other suggestions to ensure I have service at no additional cost to my plan
  • 5960 replies
  • November 20, 2021
Hi @Kissinangel If you have added both Easy Roam INT and the pay per-use roaming add ons, you should be able to use your Koodo plan in Cuba at a $13/ day, on top of your Koodo plan. Here you can find out more: https://www.koodomobile.com/easyroam
