phone is showing important display message. what does it mean(?
  • Apr 29, 2023 10:49 PM UTC
  • 2 replies
  • 316 views
Got a pre owned phone last week and it’s showing in my settings “important display message”
  • Apr 29, 2023 10:58 PM UTC
This means that during the refurbishing process, a non-genuine Apple part was used. In this case, the display is not a genuine Apple part. You can return the iPhone if this is not what you were expecting. Or you can keep the device if you’re okay with this.
https://support.apple.com/en-us/HT210321
  • Apr 29, 2023 11:26 PM UTC
Eek, that is not a good sign. I would suggest you to return your phone within the 30-day period if you decide you do not want to keep it. Assuming you ordered it online, you can send an email to the Koodo Web Store at koodo.webstore@koodomobile.com to start the return process.
