new unlocked phone, same prepaid plan
  • Mar 22, 2022 8:08 PM UTC
  • 2 replies
  • 324 views
I currently have a prepaid plan. My current phone is getting old so I’m looking into buying an unlocked phone from a store. Will I be able to put the SIM I have currently into the unlocked phone and continue to remain on my prepaid plan?
  • Mar 22, 2022 8:09 PM UTC
That's correct. That's the beauty of Sim cards. And be sure to use whatever app that your phones manufacturer uses to transfer over everything as well.
  • Guardian
  • Mar 22, 2022 10:32 PM UTC
Most new handsets use a “nano” SIM.  If your phone is very old your SIM maybe the older and slightly larger “micro” size.   You will need to buy a new tri-cut SIM card if your old phone is using the older and larger SIM.
If you end up having to use a newer SIM card you can use the online account to do the swap.
