Which long distance add-on will be used if I call UK from Canada?
  • Apr 8, 2023 5:51 PM UTC
  • 2 replies
  • 237 views
On my add-ons I have both of these:
  • $0 Int'l Long Distance Saver
  • Pay-Per-Use Intl Long Distance
I can’t remove the Pay-Per Use add on.
Two questions:
  1. If I call the UK, which one of these add-ons will be used to bill me?
  2. How much does the Long Distance Saver plan cost? In my add-ons it is listed at $0 per month, but in some documentation, it says it costs $5 per month.
Thank you.
  • Apr 8, 2023 6:22 PM UTC
Two questions:
Thank you.
It would be a good idea to keep the International Long Distance Saver add-on, so you can get access to better rates when you are making calls to the UK.
  • Apr 8, 2023 6:33 PM UTC
For just $5/month, the International Long Distance Saver add-on, which you can add to your account in Self Serve, lets you chat for as low as $0.05/min. All long distance calls use anytime minutes.
Since this is a paid add-on this should trigger the International Long Distance Saver first, bypassing the Pay-Per-Use Int’l Long Distance add-on. The article linked below might explain this better.
