Visual Voicemail TCL Pro 20 FROM Koodo
  • Mar 23, 2022 5:30 PM UTC
  • 4 replies
  • 219 views
Is there a reason that this Android Phone that Koodo sells can’t be activated? It’s been waiting to be activated on my phone for some time.
I don’t see it on the list, however this phone was purchased straight FROM Koodo themselves, it’s Android.
If it Can’t be added, is there a reason there’s no warning so people aren’t wasting their money?
When might be be added?
Best answer by Flo Koodo
 Hi @Pheonix Deloures
Unfortunately, no TCL model is compatible with the visual voicemail at the moment. This would depend on the manufacturer if it will be included with future software updates.
Here is a list of the current devices that support visual voicemail: https://www.telus.com/en/on/support/article/visual-voicemail-for-android#capable_android_devices
  • Mar 23, 2022 5:57 PM UTC
These are all very good questions. Let me flag a rep for you.
Also when did you purchase your device?
Even the Samsung S22 ultra doesn't have VVM
Thanks for your help.
Purchased device a month ago from Koodo online.
  • Mar 23, 2022 8:22 PM UTC
  • Mar 24, 2022 12:28 AM UTC
If you purchased online you have 30 days to reutn the phone. I would check that as quick as possible if you want to return the device
https://www.koodomobile.com/help/returning-or-exchanging-your-koodo-phone
