is there koodo roaming charges if I’m using other carrier esim while in the USA
  • Sep 14, 2021 3:58 PM UTC
  • 2 replies
  • 351 views
I have a koodo SIM card in my iPhone 11 on a post paid plan with easy roam. I’ll be getting an eSIM with another carrier when I’m traveling in the USA. What should I do to prevent getting charged roaming charges by Koodo while I’m in the USA using the other carrier’s eSIM?
Best answer by Mayumi
If you don't need Koodo's service, I would remove Koodo SIM from device.
Then no leakage or anything.
  • Sep 14, 2021 4:03 PM UTC
Is there a way to tell your phone to use the ESIM as primary?
Mayumi
  • Sep 14, 2021 5:39 PM UTC
