My Koodo home Internet keep disconnecting and reconnecting today
  • May 20, 2026
  • 89 views
I wonder if this happens to others: my Koodo home Internet keep disconnecting and reconnecting today.
I turn off  and turn on the modem/router power several times already to try to fix it, but it does not help.
Best answer by Darius Koodo
Hello ​@Paola.m , ​@two_user Some intermittent issues with internet were experienced in Ontario this morning. It has since been resolved, and your Koodo Internet service should now be back up and running. Be sure to restart your modem and re-test!
  • May 20, 2026
this does seem to be happening to a number of users currently. Home internet and mobile internet both flaky | Koodo Community
Just to confirm, have you attempted the troubleshoot the issue by resetting the equipment or by using the Koodo internet app? Troubleshooting with the Koodo Internet app | Koodo Mobile
  • Member
  • May 20, 2026
My internet is doing the same thing. I have rebooted it and all the lights are on
  • Advisor
  • May 20, 2026
Yes. According to your link to the community, this happens to a lot of users.
I don’t think this is the issue which the users can solve. This might happen at the service provider end.
I wonder if it happens to just Koodo Internet or all to use Rogers cable.
  • May 20, 2026
I agree, I suspect there is currently an issue of some kind on the provider end.
Similar to the other Mobile Master on the other post, I will flag a rep to this one to investigate. They will respond here as I have, note response times can vary but they should be able to provide an update on the issue.
  • Advisor
  • May 20, 2026
Looks like the issue has been fixed.
Hope no problem any more.
Darius Koodo
  • May 20, 2026
