My Koodo Data is not working after I changed my plan.
  • Dec 29, 2023 3:22 PM UTC
  • 621 views
Yesterday night, I changed my Koodo mobile Plan which is 50.00 per month with 70 GB of Shock -Free Data at 5G speed. And today morning, the data is not working so I couldn’t do my work in this morning.
Please help me. Thank you.
Best answer by Sophia
Right, but your billing cycle is from the 28th (yesterday) till the 27th. You should definitely be good for data now :)
Can you try to reboot your phone? What phone is it? Is there anything else that you did when you changed plans which might effect your data?
Sophia
  • Dec 29, 2023 3:25 PM UTC
Have you checked self serve if you still have data left this round due to proration? What is your billing cycle?
  • Dec 29, 2023 3:29 PM UTC
I alreadt checked it...
I usually pay my bill on the first day of the month.
Sophia
  • Dec 29, 2023 3:54 PM UTC
  • Dec 29, 2023 7:19 PM UTC
Silly question, but was your data working prior to you changing plans?  Like did you have a data plan previously that you actively used?
  • Dec 30, 2023 1:16 PM UTC
Wow..Thank you so much for your kindness. :)
I solved the problem. I was an Idiot.
Have a good weekend. Thank u.
  • Dec 30, 2023 1:20 PM UTC
I solved the problem thanks to Sophia who gave me the answer. As you know, It was silly question.😅
Anyway. Have a good day.
