Why have I been charged data for sending picture texts?
  • Jul 14, 2022 7:56 PM UTC
  • 3 replies
  • 480 views
I have been charged $7 for data. I only turned it on to send picture texts which I am not supposed to be charged for. Please refund $7 plus tax. Thank you!
Best answer by Dinh
It says I have to switch data on to send the message.
It used 0.2988mb.
 MMS required cellular data to be enabled to be sent so the phone asked you so. If you didn’t want other app to use data, you must restrict them in the phone by playing around with APN (Android only) or get a data block (but allow MMS) from Koodo (not free).
Anyway, if you are using a plan without data, I suggest you to use a prepaid plan. It is easy to control. Also, look into the “starter plan” options
  • Jul 14, 2022 8:17 PM UTC
MMS itself is free to send/receive. However, once you turned on Data, everything in the phone will access data also.
Could you check the data usage section and see how much data was consumed after you turned on Data?
  • Organizer
  • Jul 14, 2022 8:41 PM UTC
It used 0.2988mb.
  • Jul 15, 2022 4:58 AM UTC
It used 0.2988mb.
