Unintentional roaming
  • April 25, 2026
  • 7 replies
  • 91 views
Good afternoon, I recently returned from a trip to Ireland and have 5 roaming charges on my bill ($86 worth) for the following dates: March 20/26, March 21/26 x2, March 31/26, April 3/26.  It says the duration for each is only 1 minute (I did not place any calls, etc.) I used a Saily esim when I was in Ireland so I am thinking my roaming was left on by accident (not sure if the plane picked up towers in the US, UK, etc)? Are you able to remove these charges?  It would be greatly appreciated as the esim I bought in Ireland was also very expensive. Thanks so much!
Best answer by Dennis
Let me flag a rep to see if the easy roaming charges due to data leakage can be reviewed.
  • April 25, 2026
Easy roam is triggered when you send a sms, or use any data or talk with your koodo sim.
The 1min ER/VC charge just shows when easy roam is triggered by some kind of use.
Follow the article below to determine what triggered the roaming charge. Was it talk or text or did data leakage occur?
https://community.koodomobile.com/plans-services-232910/why-was-i-charged-for-easy-roam-7818664
  • April 25, 2026
Thanks for the response, Dennis - it looks like data leakage occurred for each of those (so my data must have been left on unintentionally).
  • April 26, 2026
I recommend checking how much data was used. If it is more than 1MB, Koodo might not be able to waive the fee since it counts as actual usage
  • April 26, 2026
Thanks Dinh, looks like the charges on March 31st and April 3rd were both less than 1MB (0.16 MB and 0.41 MB).
  • April 26, 2026
  • April 26, 2026
@nikkicar
We have looked into it and we have been able to apply a credit for the 2 days since they usage was due to data leakage, however for the rest, there is higher usage.
We recommend checking the article shared by Dennis above to find out more about how to prevent unwanted roaming charges.
We also recommend checking the Travel Pass options here in the future in case you travel in one of the regions/countries covered by the travel passes: https://www.koodomobile.com/en/help/europe-easy-roam-travel-passes
  • April 28, 2026
Great, thank you so much!
