long distance charge to a canadian number
  • Oct 22, 2023 6:50 PM UTC
  • 3 replies
  • 301 views
Hi! Struggling a bit to understan why I received a long distance charge for a call to a canadian number. My plan includes free canada-wide minutes so I’m unsure why this happened, especially because the area codes were the same for my number and the number I called. Is there any way I can dispute the charge? Or else figure out why it happened.
Best answer by Flo Koodo
Hi @leah337
We have checked and we can see that your current plan comes with 100 outgoing nationwide minutes. The charges were incurred for the nationwide minutes used on top of the 100 included. (Nationwide minutes are considered when you call from your current province to a different province). For example., if you make calls while you are in ON and you already used the 100 nationwide minutes, overages will apply for the calls made to a province other than ON.
  • Oct 22, 2023 7:26 PM UTC
Hi @leah337
  • Oct 22, 2023 8:36 PM UTC
@Flo Koodo Oh thanks, that helps to know that nationwide is distinguished from calls within the province. Is there a distinction between outgoing and incoming calls? Or do those 100 minutes include incoming nationwide calls as well?
  • Oct 22, 2023 9:22 PM UTC
@leah337  Your plan includes unlimited incoming nationwide minutes. Only the outgoing nationwide minutes are limited to 100 minutes per bill cycle.
I hope this helps :)
