Wireless Home Phone and existing phone jacks
  • Dec 16, 2024 10:30 PM UTC
  • 4 replies
  • 254 views
Is it possible to connect the WHP hub in such a way that I can also use all the existing wall jacks in my home? I know this is possible with Bell’s home phone modem/hub and perhaps Rogers’ as well.
Best answer by Allan M
Yes you would just have to plug it into the appropriate starting point so that it disperses to all the jacks. (Likely where it is currently plugged in for you.)
Allan M
  • Dec 16, 2024 11:01 PM UTC
  • Dec 17, 2024 1:05 AM UTC
Thanks for the reply Allan.
May I ask where you come across this  information or how you come to your conclusion?
Allan M
  • Dec 17, 2024 1:25 AM UTC
Just from personal wiring experience!
Wall jacks throughout a house start at an initial point, are split, and then extended throughout a house. As long as you plug in your box to the starting point before it gets split and extended, then it will all work successfully.
  • Dec 17, 2024 1:31 AM UTC
Thank you very much for the info. It is greatly appreciated.
