Will I be charged roaming for checking my Voicemail from a different phone?
  • Jun 13, 2023 7:54 PM UTC
  • 1 reply
  • 406 views
While I am in roaming abroad and not activated Easy Roaming , if I check voicemail from landline/another phone by dialing into my cell number and  press * to access my voicemail, will there be any roaming charges?
Best answer by Dinh
If you call your voicemail from another number, there isn't any charge on your line. You shouldn't be charged roaming fee for that.
1 reply
  • Jun 13, 2023 9:39 PM UTC
