wifi calling won’t activate after port
  • Dec 24, 2023 1:37 PM UTC
  • 2 replies
  • 517 views
I ported to Koodo on Friday and wifi calling will not activate on my iPhone. Returns an error saying to contact Koodo to allow.
Best answer by JTB6
Tech support fixed the issue. Thanks!
  • Dec 24, 2023 5:21 PM UTC
How about your call and text? Is everything else work normally? Can you check the status of your number transfer in selfserve.?
as well, which phone are you using? I assumed you are a postpaid customer?
  • Rockstar
  • Dec 25, 2023 5:50 PM UTC
