Wifi calling OnePlus 9
  • Jun 29, 2023 4:06 PM UTC
  • 7 replies
  • 299 views
Hi EveryOne
Wifi Calling stopped working since the latest security update that happen end of May till this Month .
Did anyone find a workaround or solution ?
  • Jun 29, 2023 5:02 PM UTC
Wifi calling was never available for oneplus device in Koodo network though. I wondered how you used it previously. Was it only showing up as a setting or you actually used it on WiFi?
  • Jun 30, 2023 12:48 AM UTC
Hi EveryOne
I am not sure if this method still works, but you may want to give it a try. Make sure to back up your phone before going ahead with the process. https://community.oneplus.com/thread/1284987
srlawren
  • Hero
  • Jun 30, 2023 4:56 PM UTC
The other thing you might need to do is set/update your e911 address.  More details here:
  • Jul 3, 2023 2:39 PM UTC
@Dinh , yes it was working recently my OnePlus 9 5G ,  bought from Amazon , it was working till i applied the latest security patch , I found its security bug that prevent VOLTE Service
  • Jul 3, 2023 2:40 PM UTC
  • Jul 3, 2023 3:01 PM UTC
Its already setted thank you . I guess its different issue then
  • Jul 3, 2023 8:00 PM UTC
The security patch was delivered by OnePlus. As the device wasn't a Koodo device, it wasn't pushed by Koodo.
Anyway, not sure how you made it work. I don't recommend you use side loading customized firmware for security reasons.
