Wifi calling not working on Pixl 6a
  • Nov 25, 2022 9:33 PM UTC
  • 12 replies
  • 326 views
Hello, I received a new Pixl 6a from Koodo a few months ago and it appears that my WiFi caling is no longer working. It previously worked on my Pixl 4a.
I’ve tried restarting my phone and re-enabling wifi calling but the phone keeps telling me to contact my carrier...
Is there a setting that needs to be changed on my account?
Best answer by Boa_Guy Koodo
Hi there @Bella_Moo  The VoLTE add-on has been added to your account. You can now finish activating it.
Cheers,
  • Nov 25, 2022 9:46 PM UTC
Can you verify that the VoLTE access add-on is visible in your Self Serve account?
If the VoLTE add-on is not there or cannot be added, a rep will have to add this to your account. Once the VoLTE access add-on is added, Wi-Fi calling should work.
  • Nov 25, 2022 9:50 PM UTC
Hello, I do not see it in my self serve or as an available add-on. I sent a message to Koodo via FB as I can’t receice a callback at the moment (I depend on wifi calling at home! :))
Thanks,
  • Nov 25, 2022 9:54 PM UTC
Thanks,
Understood. If you don’t get a response by later today or tomorrow, let us know. We can flag a rep to help. Keep us posted.
  • Nov 26, 2022 5:15 PM UTC
Good morning, still no response from Koodo. Is it possible to flag a rep?
Thank you!
  • Nov 26, 2022 5:18 PM UTC
Thank you!
Done.
Boa_Guy Koodo
  • Koodo Alumni
  • Nov 26, 2022 5:29 PM UTC
Cheers,
  • Nov 26, 2022 5:59 PM UTC
Thanks!
WiFi calling not working. Pixel 6a, tried rebooting and powering off/on still not working.
  • Nov 27, 2022 11:28 PM UTC
@Audrey Farber When you login to your Self Serve account, do you see the VoLTE access add-on?
To check, login to your Self Serve account, click on the Self Serve tab. From the dropdown menu, select Mobile services, under My add-ons, select Manage add-ons and check whether the VoLTE access add-on is in the list or not. If not, let us know.
Thanks for getting back to me and no VoLTE is Not listed.
Boa_Guy Koodo
Hi @Audrey Farber
We have added the VoLTE feature, please restart your phone, you should be able to enable it.
Everything seems to be fine now.
Thanks for your help.
