wifi calling not working
  • Jan 17, 2023 3:01 PM UTC
  • 7 replies
  • 215 views
I’ve gone through all the troubleshooting steps, looks like I (and my phone) meet all the wifi calling requirements, but it’s not working. Should VoLTE be showing as an option?
  • Jan 17, 2023 3:14 PM UTC
Which phone model was it? And can you check your selfserve>>plan and addon to see if you had the "volte access" addon there?
  • Jan 17, 2023 3:40 PM UTC
Thanks for your support. VoLTE is on my list of addons. I have an iPhone Xs.
  • Jan 17, 2023 3:55 PM UTC
It should work. When you activated wifi calling, was there any error message? https://www.koodomobile.com/en/help/wifi-calling
  • Jan 17, 2023 4:19 PM UTC
I think it should work as well, but 🤷🏻‍♀️
no error messages. It just doesn’t kick in when needed and VoLTE doesn’t show in my options.
  • Jan 17, 2023 8:04 PM UTC
The Volte button was removed to the cellular settings in  newer ios. You can go there and set “data & voice” to LTE. That should enable volte.
Regarding the vowifi, Koodo vowifi only kicked in when their cellular signal wasn't sufficient. You can test it by enable airplane mode when connecting to wifi
  • Jan 17, 2023 8:11 PM UTC
Thanks again 😊
That clarifies that VoLTE shouldn’t be an option. Thanks. LTE is z as n option and selected, but wifi calling still doesn’t kick in on airplane mode or when my signal is non existent. Mystery continues
  • Jan 17, 2023 8:15 PM UTC
Thanks again 😊
Try to disable vowifi and reenable it again. Also which wifi ISP are you using? Some certain ISP had issue with Koodo wifi server.
