why do incoming calls need to press a number to connect?
  • Mar 1, 2022 8:29 PM UTC
  • 1 reply
  • 2324 views
Mika Frost
iPhone user here,
I’ve checked my phone settings and I don’t believe this is happening due to my iPhone so I’m asking Koodo members for help!
When someone unknown or a number that has never called me before tries to call me, they are prompted to press a number before being able to connect to a call.
Why would this be happening? I’ve missed very important calls due to people being confused about the prompt to connect to a cell phone number, I’m hoping I can have some help on fixing this without having to wait on hold with Koodo customer service.
I really appreciate the time
1 reply
Allan M
  • Mar 1, 2022 8:53 PM UTC
Sounds like the feature call control. If you login to your self serve account you should see it under your add-ons if it's there.
