VoLTE doesn't work even enabled
  • Jul 15, 2023 9:57 PM UTC
  • 15 replies
  • 670 views
Hi
I enabled on the phone and on the self serve portal. the VoLTE still doesn’t work. I have another provide on the same phone and it is working fine. See photo below.
SIM1 - Koodo (not working)
SIM2 - FIDO (working without any issue)
  • Jul 15, 2023 11:04 PM UTC
Have you tried restarting your phone?
This may help resolve the problem. If not, try resetting your phone’s network settings.
  • Coach
  • Jul 15, 2023 11:40 PM UTC
Tried many times with no luck. Might be Koodo needs to do something on their end. Activate the volte on my profile? I don't know. Fido works fine on the same phone. See photo. IMEI needed might be, I don't know
  • Jul 15, 2023 11:42 PM UTC
Do you see the VoLTE add-on in your Self Serve account?
  • Coach
  • Jul 15, 2023 11:43 PM UTC
Yes.
  • Jul 15, 2023 11:52 PM UTC
Technically, the Realme phone is not supported by Koodo for VoLTE or Wi-Fi calling. Can you post a screenshot of your APN settings?
  • Coach
  • Jul 15, 2023 11:54 PM UTC
  • Coach
  • Jul 15, 2023 11:55 PM UTC
Fido also tell me the same thing but it works right away without any issues
  • Jul 16, 2023 12:06 AM UTC
Everything with the APN appears to check out with the exception of the mvno type. The ‘mvno type’ should be set to GID. The ‘mvno value’ should auto-populate with an alphanumeric code.  If you’re not using the other APN’s (TELUS), delete them. Remember to save any edits made to the APN settings.
I’m not sure if this will resolve the VoLTE problem. Reading previous posts from earlier in the week, there appears to have been some problems with LTE affecting customers all over Canada, which may affect VoLTE/Wi-Fi Calling.
  • Coach
  • Jul 16, 2023 1:34 PM UTC
I checked,
On FIDO, it said IMS registered
On Koodo, it said IMS not registered
I think there is something to do with Koodo. Maybe they have to whitelist the IMEI. They seem to block all the BYOP devices. It is not fair
I switched MVNO type to GID but no luck.
  • Jul 16, 2023 5:05 PM UTC
You may have lucked out with Fido. It comes down to devices that are not sold by the carrier or are not officially sold in Canada. Provisioning a device with VoLTE/Wi-Fi Calling is generally not an issue when a BYOP is purchased directly from Apple, Google or Samsung, all of which are officially sold in Canada.
You can check if your phone is supported by visiting the TELUS VoLTE compatibility page and entering your phone’s IMEI number.
  • Coach
  • Jul 16, 2023 7:25 PM UTC
 I put in freedom mobile sim card to replace Koodo sim card. My phone works with volte on both simcards at the same time. My best conclusion is Telus/ Koodo do something on their end and they want to make sure that they can sell their cellphone with or without contract to make money. Technology is not the limitation but the business model is.
  • Jul 16, 2023 7:57 PM UTC
It’s due to a lack of competition in this country, but I digress. Glad to hear VoLTE is working.
  • Coach
  • Jul 16, 2023 10:19 PM UTC
Only Kodoo doesn't seem (want) to work.
srlawren
  • Hero
  • Jul 17, 2023 10:46 PM UTC
Fido is known to be more liberal for sure.
Try the workaround of updating your physical address using the Telus page I linked here:
It may or may not work but is worth a try.
  • Coach
  • Jul 18, 2023 5:41 PM UTC
Tried. Koodo phone number doesn’t seem to work.
The second link is not working
