Voicemail: extended absence not working
  • Sep 29, 2023 5:53 PM UTC
  • 10 replies
  • 727 views
I activated Extended Absence with a custom greeting. It was working two months ago but it stopped working recently. Something changed on the carrier side.
Today I logged in to voicemail to try to deactivate and reactivate the extended absence. That appeared to be successful, but the standard greeting plays and not my custom extended absence greeting. Please fix this.
Best answer by profpoly
Solved! Thanks to a Koodo agent, I found out that iPhone was causing the problem.
iOS 17 (released Sept 2023) has new feature called Live Voicemail, which intercepts unanswered calls and delivers a voicemail-like service directly from the phone. This interferes with the carrier Voicemail service.
Live Voicemail is enabled by default, unbeknownst to users like me. The solution was to turn it off under Settings / Phone / Live Voicemail.
  • Sep 29, 2023 10:01 PM UTC
I wonder if your voicemail was reset somehow.
Was the old greeting messages still there in your voicemail system. If you would like to have your own new extended greeting, can you re record in your voicemail?
  • Rockstar
  • Oct 5, 2023 3:44 PM UTC
Hi Koodo. This remains a problem. Please follow up.
  • Oct 5, 2023 3:48 PM UTC
did you try re-recording your extended absence greeting?
  • Rockstar
  • Oct 5, 2023 3:59 PM UTC
No, the custom absence greeting is correct. It just never plays on answer.
  • Rockstar
  • Oct 29, 2023 5:02 PM UTC
I’m disappointed by Koodo’s disinterest in client support.
  • Oct 29, 2023 5:05 PM UTC
Have you contacted Koodo? If so what did they say?
  • Rockstar
  • Oct 29, 2023 5:06 PM UTC
I had a callback with an agent a few weeks ago. They didn’t resolve the problem and never followed up.
  • Oct 29, 2023 6:25 PM UTC
Let me flag a rep to help you out.
  • Oct 29, 2023 6:55 PM UTC
Hi @profpoly
We are sorry about this experience!
We have sent you a PM so we can further assist, please check it our when you get the chance, thanks!
  • Rockstar
  • Oct 30, 2023 11:11 PM UTC
