upgrade to VoLTE
  • Oct 7, 2026 4:56 PM UTC
  • 60 views
i recently received a text about upgrading my Samsung A50/S4 to VoLTE with links to check compatibility and instructions in settings to change toggle .I did change when I saw LTE so assume it's fine but have until March 2027 or need new hardware. can anyone decipher what I'm saying as im elderly and low Teck. id really appreciate your advice
Best answer by Allan M
If when you make a call, you still see it say LTE on your phone then you’ve successfully turned it on. If it switches to 3G as soon as you make a call, then it is not enabled.
Allan M
  • Oct 7, 2026 7:05 PM UTC
  • Oct 7, 2026 8:54 PM UTC
hi Allen
thank you so much for replying i really appreciate you. just wondering where I check to see if it says LTE when I make a call?
  • Oct 7, 2026 9:08 PM UTC
Hi ​@brookelynn
this will be in your top right corner of your screen when you make a phone call, it’s in the same spot as when you use mobile data.
When you place a phone call, the LTE symbol will remain in the top right corner when you’re on VoLTE. If not, it will switch to “3G” being displayed instead. If it switches to 3G, then the device is using the 3G network to make the call as opposed to VoLTE.
  • Oct 7, 2026 9:48 PM UTC
so thankful for your help Oliver. I made a call but no symbols were displayed but Wi-Fi and battery but when I turned on my mobile data the LTE was displayed! I hope that means I did it right thanks to you of course. am I assuming this? if I don't hear from anyone ill know I did it right!
  • Oct 8, 2026 12:26 AM UTC
I apologize for the delayed response. That’s exactly right - to have the indicator appear it’s best to turn off wifi and have data enabled. This is encase you have wifi calling enabled, causing the LTE logo to not appear in addition that your tool bar in the top right can only display so much at once. So when wifi is enabled it may not show this. You did the right thing.
Where you saw the LTE indicator, made the call, and it did not change shows that you’re calling over the VoLTE network and that the device is correctly setup and compatible. I hope this confirmation helps. 🙂
  • Oct 8, 2026 1:03 AM UTC
o my goodness i wasn't sure how asking the community would go but im so impressed as it's been a good experience and i appreciate the kindness, patience and quick replies. thanks again Oliver and Allen !
