trying to unlock my phone
  • Oct 11, 2022 9:29 PM UTC
  • 4 replies
  • 494 views
Eric Lafortune
I have an old koodo phone I am trying to put another Sim card into it and it's asking for a pin.
*********0330707
Was told I can get the unlock pin from koodo using these numbers.
Best answer by rikkster
You should be able to unlock your phone from within your Self Serve account.
To unlock your phone online:
  1. Login to Self Serve
  2. From the Self Serve dropdown menu, select Mobile services
  3. Select Unlock your phone
  4. Enter the required information, then submit
Successful unlock code retrieval for non-iOS phones: We’ll show you the unlock code and send a confirmation email with the code in it.
Unlocking your phone | Help
  • Oct 12, 2022 1:10 AM UTC
Eric Lafortune
I do not have a self serve account,  I am no longer a koodo customer
Boa_Guy Koodo
@Eric Lafortune  We have sent you a PM, so we can further look into this, please check your inbox when you get the chance
Eric Lafortune
Thank you very much for your support
