travel to Bahamas using whatsapp
  • Apr 20, 2022 2:13 PM UTC
  • 1 reply
  • 475 views
Is it possible to travel to the Bahamas and only bring my phone to use WhatsApp? Will I be charged roaming fees?
Best answer by Sophia
WhatsApp uses the internet. If you stay on WiFi only or get a local SIM card, it won't cost you any roaming fees.
But if you use WhatsApp with your Koodo line, that uses data and it would trigger roaming.
1 reply
Sophia
  • Apr 20, 2022 2:31 PM UTC
