Text Not Always Sending
  • Jul 3, 2022 11:48 PM UTC
  • 3 replies
  • 336 views
I have a Samsung Galaxy S20 fe 5g phone. I have been having trouble with texts not sending. I seem to be able to receive texts no problem.
  • Jul 4, 2022 3:13 AM UTC
As Koodo hasn’t  supported 5G yet, I suggest you turn off 5G and default the phone to LTE/HSPA. That might help with the battery and signal.
As all newer  Samsung phone model supported RCS. RCS also request a data connection. The issue could be from that also. Can you try to turn off RCS in the phone and see if it helps?https://www.koodomobile.com/en/help/next-generation-messaging
  • Ambassador
  • Jul 4, 2022 1:20 PM UTC
Thank you for your reply.  I have turned off chat on my messages but you mentioned switching to LTE/HPSA.  My phone only has LTE/WCDMA/GSM (auto connect), WCDMA/GSM (auto connect), WCDMS only and GSM only.  Could you tell me which of these would work to turn off 5G?
  • Jul 4, 2022 1:47 PM UTC
If you didn’t see the 5G, your phone might run the Koodo firmware already. As such, you don’t have to do anything. 5G was already off.
