Stolen phone and sim card
  • Sep 8, 2026 1:16 AM UTC
  • 15 replies
  • 206 views
My phone got stolen 3 hours before and I want to talk to Koodo right away or within an hour from current time. Please let me know asap so that I can give my friend’s contact number here. Thanks.
Best answer by Dinh
Are you a prepaid or postpaid customer? For prepaid you can suspend the service yourself right away in Prepaid Self Serve https://prepaidselfserve.koodomobile.com under the Profile tab, Report Lost / Stolen Phone.
For postpaid it goes through a rep, connect to one through Koodo Assist on https://www.koodomobile.com/en/help/reporting-your-lost-or-stolen-phone and they can suspend the line. If you schedule a callback it just has to be a Canadian number that can receive incoming calls, so your friend's number works fine for that.
While you wait, use your Apple or Google account to remotely lock or erase the device. Keep in mind you are still charged for the plan while the line is suspended, and SIMs can't be changed online so a replacement SIM has to go through a rep or a store.
  • Sep 8, 2026 2:04 AM UTC
  • Advocate
  • Sep 8, 2026 2:17 AM UTC
I have canadian number, please call me on **********
**edited by moderator to hide personal information
Hi ​@Arya_07, we’re sorry to hear about your phone. Unfortunately, we can’t call you here but you can schedule a callback after talking to our Expert Messaging team via the Koodo Assist
You can also flag your phone as lost/stolen via the Koodo Assist, here is more information.
  • Advocate
  • Sep 8, 2026 3:17 AM UTC
I talked to them already, so can you call me within 15-20 minutes?
  • Sep 8, 2026 7:15 AM UTC
Unfortunately, reps in the forum can’t call you. If you prefer speaking with someone, you’ll need to schedule a callback through Koodo Assist.
By the way, were you able to successfully suspend your line using it?
  • Advocate
  • Sep 8, 2026 2:08 PM UTC
Yeah, I did that but i want to know the serial number so that i can give it to police. i am the customer of koodo from a very long period of time.
Allan M
  • Sep 8, 2026 2:34 PM UTC
If you are a postpaid customer, and purchased the phone from Koodo you can follow the steps here to download your service agreements. If you find the one where you purchased the phone, it should have the IMEI number on it.
https://www.koodomobile.com/en/help/viewing-and-downloading-your-customer-service-agreements-csa
If not, you can give more info on what phone model it is, where you bought it, if you’re prepaid/postpaid and we can try to help find other ways to track the IMEI down.
  • Advocate
  • Sep 8, 2026 2:45 PM UTC
so my phone model is iPhone 14 pro max and I bought from Walmart situated in Etobicoke, ON. I do not know how to find out either i am prepaid or postpaid but i usually pay monthly i mean the amount is deducted from my account every month.
  • Advocate
  • Sep 8, 2026 3:49 PM UTC
How can I find that IMEI number from that pdf?
  • Sep 8, 2026 3:59 PM UTC
If you have the service agreement, there should be a section that gives the phone detail with a long serial number (IMEI).
If you have the phone registered with Apple, then Apple should have it too.  And it is also on the box the phone came in.
  • Sep 8, 2026 4:00 PM UTC
Hi ​@Arya_07
If the phone was purchased at Walmart, you can check the invoice/ agreement. The IMEI might also be displayed on the original box of the device (15 digits).
Another option is to access check the device with your Apple ID: https://discussions.apple.com/verify-human/verify.html?next=/thread/3840664
  • Advocate
  • Sep 9, 2026 12:01 AM UTC
how can I stop the service with koodo on that phone and am i able to use the same number?
  • Sep 9, 2026 4:58 AM UTC
You can port the number to another provider and this will automatically cancel your koodo service and you will be charged a final bill, including any tab and tab bonus charges if applicable.
If you just cancel your koodo line, then the number will not be able to be moved.
  • Advocate
  • Sep 9, 2026 12:22 PM UTC
why don’t you call on the above given number as I want to stick with same offer that koodo gave me for my postpaid plan and they told me that if i would change my phone then this offer is not going to be applicable, although it was just recent one that i got as well as i have been the customer of koodo from almost 2.5 years.
  • Sep 9, 2026 1:26 PM UTC
The rep already mentioned that they couldn’t call due to system limitations and Koodo’s process. You’ll need to schedule a callback from a Koodo prepaid rep through Koodo Assist. The links are posted above..
