Sound crackles and skips when using Easyroam
  • Apr 8, 2024 3:03 PM UTC
  • 124 views
I have an UMIDIGI G1 Max phone running Android 12.  When I make a voice call here in Toronto the sound is fine.  When I made voice calls in the US (North Carolina hooked up to AT&T I believe) the sound is unusable - it crackles and drops short sections.  How can I address this problem?
Best answer by Dennis
Are you using VoLTE when in the US?
https://www.koodomobile.com/en/help/3gshutdownUS
  • Apr 8, 2024 3:57 PM UTC
Hi @Valis Inc.
Have you tried switching to a different carrier, if available or test the sim card on a different phone?
  • Organizer
  • Apr 8, 2024 4:21 PM UTC
Unfotunately, I didn’t have another phone to swap the sim card out.  I wasn’t aware that I could choose different carriers when traveling.  I guess one would do that in the “choose network” settings?
  • Apr 8, 2024 4:56 PM UTC
Yes, you should be able to switch from Automatic to Manual network in the network settings, and then select a different network carrier to connect your phone to.
  • Organizer
  • Apr 8, 2024 5:05 PM UTC
If the problem persisted across different US networks what else might cause crackling/dropped sound on voice?
  • Apr 8, 2024 5:28 PM UTC
  • Organizer
  • Apr 8, 2024 6:01 PM UTC
I’m not sure where VoLTE is accessed specifically but the preferred network type was set to 4G/3G/2G/Auto.  I noticed it was currently connected to 3G (I’m in the basement).  I went upstairs and got connected as LTE and came back down and it’s now on LTE.  It may have been connected as 3G in the US.  The data seemed to work fine.  Note: I am currently having a hotspot not sharing internet problem.  I did a separate thread on that issue:   No internet available through hotspot | Koodo Community (koodomobile.com)
Thank very much for your help!
