someone help me to unlock my iPhone 6s
  • July 9, 2026
  • 9 replies
  • 82 views
Hello i have an iPhone 6s need to unlock help me
Best answer by Oliver C
I will flag a rep on here to see if they can assist with the unlock of the device.
If they cannot, your other option is to schedule a call with a rep through the links provided previously and selecting “Not a Koodo customer” under “monthly - mobility”. You can then follow the prompts to schedule the call, and a rep can help you with the unlock process.
Response times on here can vary, but a rep will respond.
  • July 9, 2026
To unlock your phone, you should go to Koodo Assist and follow the steps provided. They will submit the request on your behalf and Apple will unlock your phone.
You will need to insert a SIM card from another carrier or connect to iTunes to complete the unlock process. Koodo will send you a confirmation email. https://www.koodomobile.com/en/help/unlocking-your-phone
  • July 9, 2026
Koodo will help you network unlock the device through using Koodo assist. They will submit the unlock request on your behalf and Apple will unlock your phone You can find the details for this in the link. Once done, they will send you a confirmation email. : Unlocking your Koodo device | Koodo Mobile
Just make sure you have your device IMEI handy and follow the prompts provided by the bot. Let us know if you run into any problems.
  • Coach
  • July 9, 2026
yes i have imei hand can send you here?
  • July 9, 2026
It’s good that you have it already, but no, do not send it here.
As described above, you need to use Koodo assist. A link for the chat bot can be found below. For more information on unlocking the device, please refer to the other links shared above: https://www.koodomobile.com/en/help?autobots=rollout
  • Coach
  • July 9, 2026
i’m unable send private message now
  • July 9, 2026
You can use this link to log in to your Self-Serve account and provide the details to unlock your phone.
  • Coach
  • July 9, 2026
sorry i don’t have account
  • July 9, 2026
  • July 9, 2026
Hi ​@brendagrim, we’ve sent you a private message to confirm some details. Please check your community inbox when you get the chance, thank you!
