SIM card not recognized by Samsung S21
  • Dec 31, 2021 5:14 PM UTC
  • 7 replies
  • 1236 views
So I received my new Samsung Galaxy S21, and activated the SIM card that came with it. I waited an hour, inserted it correctly into the tray, and when I try to do the setup on the phone, it’s telling me to insert a SIM in order to do the setup. But the SIM card is already inserted. I tried others SIMs and the problem is still there. When I insert the same SIM into my old phone, it’s detected automatically. Is it possible that there’s an issue with the SIM tray on the new phone?
Best answer by rikkster
Also, I can’t get to the steps in the article because I can’t start the phone’s setup because it doesn’t detect a SIM card and won’t let the setup wizard start.
To get past mobile network setup, (an area of the setup wizard) power off your S21. Remove the SIM card and leave out until after setup. Power on the S21, select language and tap Next. Connect to mobile networks should be Off, tap Next.
This bypasses mobile network setup and should allow your S21 to connect to a Wi-Fi network to complete a basic setup. When setup is complete and at the Home screen, power off the S21. Insert the SIM tray/card and power on the phone.
Check to see that your S21 has mobile network access. If the SIM card is still not detected, follow MilkyWay’s recommendation.
  • Dec 31, 2021 5:45 PM UTC
Did you have an existing Koodo SIM card? If so, when you are activating the new SIM card that came with the phone, do you mean that you swapped your old one with it on your Self-Serve account? https://www.koodomobile.com/en/help/koodo-sim-support
  • Dec 31, 2021 5:47 PM UTC
I had an existing one, but I activated the new one and tried it in my old phone and it’s recognised instantly. The S21 doesn’t recognize that a SIM card has been inserted.
  • Dec 31, 2021 5:53 PM UTC
Have you tried any of these steps? You may have to reset your network settings or do a factory reset on your phone. https://www.technobezz.com/samsung-galaxy-s21-s21-plus-is-not-detecting-the-sim-card-ways-to-fix-it
  • Dec 31, 2021 5:55 PM UTC
  • Dec 31, 2021 5:59 PM UTC
It is possible your device is having issues. I would suggest you to bring it to a Koodo store or Mobile Klinik location to get it assessed. https://www.koodomobile.com/en/help/warranty-and-repair-policy
  • Jan 1, 2022 9:26 PM UTC
Timo Tuokkola
You did restart the phone after inserting the sim, right? Most phones only scan the sim card on startup.
