Samsung Galaxy A31 compatibility
  • Sep 9, 2022 9:20 PM UTC
  • 1 reply
  • 43 views
Anyone know if the Samsung Galaxy A31 will be compatible with Samsung 4G network in central Alberta?
1 reply
Allan M
  • Sep 14, 2022 5:12 PM UTC
From a quick look, SM-A315G should be fully compatible with koodo, and SM-A315F will be partially compatible.
If you had a link for the website you’re planning on buying from we can verify if that specific model will work or not.
