"RTC Connecting" on Discord
  • Oct 30, 2021 3:38 PM UTC
  • 19 replies
  • 494 views
I recently had to replace the SIM card for my Koodo phone (Xiaomi Mi 8), and now discord voice doesn’t work :(
I noticed the issue right away, and tried changing the SIM again, but I still can’t use discord on data. wi-fi is fine, and everything else works (except my Mi Account  won’t reactivate, which is fine). Anyone else experiencing this? any way to fix it?
Best answer by Allan M
i’ve only had the issue since i changed the SIM! they worked before just fine
Can you check to make sure your APN settings match what's seen in the link below and also make sure that the koodo apn settings are selected in your phone?
This setting may also appear in your phone as "Access Point Names"
https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone
  • Oct 30, 2021 4:49 PM UTC
Can you try to log out of the discord app and log in again? Was there any error when you tried to make call?
  • Advisor
  • Oct 30, 2021 4:55 PM UTC
thanks for the suggestion! so i’ve tried this twice now, and i’ve also tried:
  • removing and re-inserting the SIM (i cannot move it into slot 2 as slot 2 doesn’t support Koodo)
  • power cycling the phone
  • manually resetting APN settings
  • starting VC on wi-fi, then moving to data (it immediately says “disconnected” followed by RTC connecting)
i want to try a factory reset, but i’m procrastinating on making sure i have my passwords/data backed up :joy:
i don’t get a proper “error” or error code, just “RTC connecting” and “Failed to connect” on loop when trying through data. Skype works, Snap works, LINE works, but not Discord ;w;
  • Oct 30, 2021 5:29 PM UTC
This is a weird error from my Google search. As it worked before on Koodo network, there shouldn’t be any error.
Can you delete the app, restart the phone and reinstall it again? I think there might be some security within discord that created the issue. Hopefully that simple action would resolve it. From my Google search, the issue could be from a VPN or firewall issue with the phone also. Did you have a VPN or a firewall/antivirus app with the phone?
  • Advisor
  • Oct 30, 2021 6:35 PM UTC
it’s very weird! i can’t find any information on it anywhere! i tried uninstalling, reinstalling, rebooting, all but buying a new phone :joy:
Allan M
  • Oct 30, 2021 6:53 PM UTC
Do you happen to have data saver turned on?
  • Advisor
  • Oct 30, 2021 10:37 PM UTC
data saver? is that in self serve? my phone doesn't seem to have that as a setting
  • Oct 31, 2021 1:08 AM UTC
It would be a setting in the app.
Or a setting in your phone's data settings
  • Advisor
  • Oct 31, 2021 2:37 AM UTC
discord doesn't have a data saver setting :( could this be like a SIM issue? or some sort of provisioning issue?
  • Oct 31, 2021 2:19 PM UTC
I’m not sure if this may be the issue causing Discord not to work, but someone else found out it was their service provider that caused it not to work. In the meantime, I have flagged a Koodo rep to look into this. https://www.reddit.com/r/discordapp/comments/fp12yk/discord_not_working_on_mobile_data/
  • Oct 31, 2021 2:45 PM UTC
Hi @midni
Just to confirm, the voice feature works properly on the other apps, such as Skype, while data is enabled and wi fi off?
  • Advisor
  • Oct 31, 2021 2:48 PM UTC
yes! so Skype, Snap, Whatsapp and LINE all work when wifi is off and data is on
Allan M
  • Oct 31, 2021 3:07 PM UTC
Just tested it out on my phone on data (with Koodo) and I was able to connect just fine so it wouldn't appear to be as a Koodo wide problem.
(Not that this necessarily helps fix your issue but helps to narrow it down)
  • Advisor
  • Oct 31, 2021 3:10 PM UTC
thanks for checking, at least! every step helps! some of my discord friends have koodo as well, and i'm the only one of them not working
  • Oct 31, 2021 3:17 PM UTC
@midni Does this issue affect only a specific dicord server or all that you are trying to use the voice feature for?
As @Allan M suggested, this doesn’t seem to be a Koodo issue or a provisioning issue, but it’s quite a weird coincidence that it started just after sim card replacement.
  • Advisor
  • Oct 31, 2021 3:19 PM UTC
so /only/ discord voice is affected. app messaging works and my other apps are unaffected, but MMS is also down
  • Oct 31, 2021 6:17 PM UTC
@midni Do you have issues with MMS feature since you changed the sim card, or it was present also with the old sim card?
  • Advisor
  • Oct 31, 2021 6:18 PM UTC
Allan M
  • Oct 31, 2021 7:09 PM UTC
  • Advisor
  • Oct 31, 2021 7:46 PM UTC
thanks for this!
