RCS Chats - Trying to verify phone number...
  • Nov 29, 2023 12:40 AM UTC
  • 8 replies
  • 1576 views
Good evening,
I am trying to active RCS chats on my Pixel 7 but that status continues to say: Setting Up - Trying to verify number.
I tried to troubleshoot however I am unable to find the option that sends me a verification code.
Any help would be appreciated.
Thank you.
  • Nov 29, 2023 5:07 AM UTC
Good evening
RCS activation doesn’t require activation code though. https://support.google.com/messages/answer/7189714?hl=en
Are you new Koodo customer? have your number transfer been complete yet?
  • Member
  • Dec 21, 2023 12:08 AM UTC
I have been facing the same problem since I ported from prepaid to postpaid with koodo. Has this been resolved for anyone ?
  • Dec 30, 2023 9:35 PM UTC
I just ported to Koodo and have the same problem as well. The Status: Setting up... Trying to verify your phone number.  Anyone knows know to fix this? Thanks.
  • Dec 30, 2023 10:09 PM UTC
Is your number transfer complete?. As well try to reset network settings of the phone to see if that can help
  • Jan 1, 2024 5:54 AM UTC
Transfer was completed.  I can make calls and receive calls.  I have also tried resetting network settings but it is not helping. 😞
  • Jan 1, 2024 8:56 AM UTC
Can you turn RCS off and on again to see if that can help? you mentioned call and data. Is your SMS working?
  • Jan 1, 2024 9:36 PM UTC
I did try turning off and on (many times) but still RCS is still not activated.  SMS is working properly too. 🤦🏻
  • Jan 2, 2024 12:15 AM UTC
I think your number transfer has issue. Are you using google message or Samsung messaging app? Try to remove and reinstall Google Messages app. If that doesn’t work, you will have to contact Koodo directly and ask a rep to look into it
