Public Mobile Sim Card for Koodo?
  • May 1, 2023 5:43 PM UTC
  • 3 replies
  • 406 views
I bought a reconditioned iPhone, it came with 2 Public Mobile SIM cards.  Can these be used with my Koodo plan?
Best answer by Robert T
Hello there,
Unfortunately, Public Mobile SIM cards cannot be used with Koodo plans as they operate on different networks. Koodo, Telus and Public all use the same towers but SIM card operates separately.
To use your reconditioned iPhone with Koodo, you can either get a new Koodo SIM card from a Koodo kiosk or order one online. Once you have your Koodo SIM card, you can activate it by following the instructions included in the e-mail.
  • May 1, 2023 5:53 PM UTC
Hello there,
  • May 1, 2023 5:55 PM UTC
Can I use the Koodo SIM card that’s in my android?  Sorry if this seems like a stupid question.
Sophia
  • May 1, 2023 6:12 PM UTC
You mean if you can use your existing Koodo SIM in your new phone that you got from Public Mobile? Absolutely!
