Problems with iPhone battery
  • Apr 2, 2025 9:14 PM UTC
  • 3 replies
  • 103 views
I bought an new iPhone 13 through Koodo 3 months ago and already my battery lasts less than a day with little usage. My phone had full battery this morning and I just read some news article and played Sudoko for max. an hour and the battery was dead at 2pm.
I does not seem possible to contact Koodo online? Do I go to an Apple Store or should I try to get a hold on some Koodo rep?
Best answer by bke
Thanks for the replies. It turned out that it was a simple app that led to the phone getting really hot and using up the battery power. Simply not using it anymore solved the problem :)
  • Apr 2, 2025 9:36 PM UTC
When you check the battery health through the phones settings, what does it say?
  • Apr 3, 2025 10:02 PM UTC
The phone is 3 months old now and is yours.  Any warranty issue you will need to go through Apple.
  • Rockstar
  • Apr 4, 2025 10:52 PM UTC
