problem when tranferring to new phone
  • Oct 31, 2026 8:12 AM UTC
  • 1 reply
  • 28 views
Transferring to a new cellular device it quit half way through. Now I can’t even open the new cellular device but it already transferred successfully. So I can’t call or text anymore and now I don’t know what to do. I have already tried swapping SIM cards. That hasn’t gave me phone back on my old device. So does anyone know how to reactivate my old phone? They are iPhones.
1 reply
  • Oct 31, 2026 1:02 PM UTC
Was this an eSIM transfer using Apple's transfer tool, or did you move a physical SIM over? If the eSIM transfer quit part way, the profile usually gets deactivated on the old phone without completing on the new one, which would explain no service on either.
Also, the SIM card that comes in the box with a new phone is inactive, so swapping that one in wouldn't give you service back.
I would try Self Serve » Mobile Services » select your number » Get help with eSIM and SIM cards, then the option to recover eSIM. If that doesn't go through, a Koodo store can transfer your number onto an eSIM voucher and scan it there.
