Poco F3 mms problems
  • Nov 19, 2021 6:41 PM UTC
  • 382 views
Rodrigo Parente
I get this Poco F3 cellphone and i have a problem to send and receive MMS. I tried the problems solution in the community and didn´t solve my problem. I can find help from a Koodo support team member?
Best answer by Dennis
Does data work?
Make sure your APN settings are correct
https://www.koodomobile.com/help/setting-data-your-non-koodo-phone
  • Nov 19, 2021 6:48 PM UTC
Does data work?
  • Advisor
  • Nov 19, 2021 6:53 PM UTC
i have a MIUI phone too and i'm also having this issue (and my APNs are all correct). no idea what causes this or how to fix, maybe it's network side?
  • Nov 19, 2021 6:57 PM UTC
Does your regular data work?
Can you post a screen shot of your APN settings?
  • Advisor
  • Nov 20, 2021 1:12 AM UTC
yes it does! everything but discord voice works (which i have yet to figure out, but it works on my old pixel 2 okay)
  • Nov 20, 2021 5:05 PM UTC
Can you post a screenshot of the second portion of your APN settings? (Tap ‘More’).
  • Nov 21, 2021 8:02 AM UTC
Please try these settings that I have on my phone. I see the MMSC address is slightly different
