Please deactivate my voicemail
  • Nov 7, 2026 12:24 AM UTC
  • 7 replies
  • 70 views
Hi I found an ancient thread saying a rep can remove voicemail on my account (the extended absence instructions don’t work). I’d like to do the same.
Would you please remove voicemail from my account? I understand re-enabling would require contacting a rep and that I might lose whatever messages are saved. All I get is scammer voicemail from blocked numbers and it’s really annoying there’s no self-serve way to remove this feature from my account.
Please remove it. Thank you.
  • Nov 7, 2026 1:06 AM UTC
You can use the following steps to deactivate your voicemail:
  1. Call your voicemail by holding the number 1 on your dial pad.
  2. Select option 3 to "Manage your greetings".
  3. Select option 4 to "Manage your Extended Absence Greeting".
  4. Select option 2 to record an Extended Absence Greeting if you don’t already have one.
  5. If you have an Extended Absence Greeting recorded, select option 4 to turn on Extended Absence Greeting.
  6. Select option 5 to block callers from leaving a message after hearing the Extended Absence Greeting.
  • Nov 7, 2026 2:04 AM UTC
Hi ​@zoffix, would you like to remove voicemail from your line completely? If so, callers will not be able to leave you a message. We’d also recommend listening to or saving the messages before the voicemail inbox is deactivated as any messages will be deleted.
  • Nov 7, 2026 4:15 PM UTC
​@Koodo
Yes, please entirely remove voicemail from my line. I don’t want anyone to leave me any messages.
  • Nov 7, 2026 4:25 PM UTC
​@zoffix
Thank you for confirming!
We have managed to remove the Voicemail feature from your plan! Please note that in case you change your plan in the future, the Voicemail will be provisioned automatically with the new plan.
Please remove voicemail from my line too! I have done all the steps and still get notifications from voicemail about messages. I clear it and shortly after i get another one. I also deleted all messages there had been, so there should not be any reason for further notifications. I am very frustrated with this to the point of wanting to downscale my phone.
  • Nov 16, 2026 2:35 AM UTC
I have flagged a rep to help you out.
  • Nov 16, 2026 3:14 PM UTC
Hi ​@Missinglandlines
We can definitely look into it for you!
Please confirm the last 2 digits of the phone number in question. Please also note that any unsaved or unread voicemail message will get deleted once the voicemail is disabled. In case of a plan change in the future, the Voicemail feature will be provisioned automatically with the new plan, so this would need removed again at that point if you don’t need it.
