OnePlus Nord N200 mobile data not working
  • Jan 27, 2022 1:18 AM UTC
  • 2 replies
  • 560 views
I bought a OnePlus Nord N200 phone. I can make phone calls with it using my KOODO sim card, but I can’t use mobile data. My mobile data is turned ON in the phone’s settings. Any advice?
Best answer by MrBucket
Okay, I managed to fix it by deleting the existing APN in my phone’s network settings and following these steps: https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone?search_api_views_article_search_fulltext=APN
  • Rockstar
  • Jan 27, 2022 1:43 AM UTC
  • Jan 27, 2022 2:18 AM UTC
For some reasons, some oneplus devices had trouble to get APN settings automatically. Customers had to manually fix it. It is great that you find the solution. Cheers!
