OnePlus 7T mobile data not working
  • Mar 7, 2022 2:09 PM UTC
  • 989 views
Similar to this person I have the dreaded “data explanation mark”
Steps I have tried:
  1. I reset the phone several times.
  2. I turned off the phone and removed and reinstalled the sim card, I also tried the second slot as my OnePlus 7T has a dual sim card tray.  Reset the phone several times.
  3. I tried the sim card in my old OnePlus 3.  It works, so presumably it’s not a sim card issue.
  4. I followed the steps to modify my APN at this link and reset several more times.
    https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone?search_api_views_article_search_fulltext=APN
  5. I then reset my APN to defaults (easily found on google, here’s one link you can follow to see what I mean) https://www.4gapn.com/ca/en/koodo
  6. Finally I reset the network settings using the following steps: From the Home screen, swipe up, then tap Settings.  Tap System > Reset Options > Reset Wi-Fi, mobile & Bluetooth.
Unfortunately none of this has helped, does anyone have any other ideas on what to do?  Regarding the APNs, I was very careful to make sure I matched the case (sp.koodo.com) as well as typo checking.  Also I live in a major Canadian city and have checked several times, it doesn’t seem that the issue is with the Koodo network.  Also data works fine over WiFi.
Thank you in advance!
Best answer by Huskerbusker
Update!  I kept searching and noticed an interesting word on someone else’s forum posting.  The OP deleted all other APNs.
I deleted all the other APNs, and then added a new one adding ONLY the info from here and nothing else: https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone?search_api_views_article_search_fulltext=APN
For now it’s working, I’ll update if this changes!
  • Rockstar
  • Mar 7, 2022 2:17 PM UTC
  • Mar 7, 2022 3:00 PM UTC
Thank you for sharing. Keep us posted if there is other issue with it.
  • Member
  • Mar 27, 2022 8:37 PM UTC
I have the same problem with my One+ 7T where the data don’t work.  I tried all the steps above and they still don’t work.  Anyone has any other advice?
  • Mar 27, 2022 10:08 PM UTC
Could you post a snapshot your apn settings here?
  • Member
  • Mar 27, 2022 10:29 PM UTC
I finally got a hold of Koodo technical service and we manually inputted all the APN data and it works now.  Hopefully for good!
